Fuel conditioners
Old Apr 21, 2005 | 11:23 AM
Labman's Avatar
Labman
Fuel conditioners
I was wandering which is better Stanadyne or Racor?
Please give reasons why.
Old Apr 21, 2005 | 09:59 PM
tn mac's Avatar
tn mac
I like stanadyne
its what ford recomends
and it really works, dont know about the racor.
Old Apr 22, 2005 | 06:05 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Becasue every little bit helps
Old Apr 22, 2005 | 08:39 AM
obxtuna's Avatar
obxtuna
I run PowerService in every tank (white bottle in winter, gray in summer). gray bottle seems to help MPG by 1-1.5 in the summer and white seems to quiet the injectors a tad in the cold. Any type is cheap insurance. Members with more smarts than I will chime in and give you specifics of why you should or should not.
Old Apr 22, 2005 | 03:29 PM
bighoss550's Avatar
bighoss550
a quart of cheap atf in 40 or so gallons does the trick in mine. less smoke, less injector noise, starts in the cold better, and it DOESNT STINK!!
oh and it costs a tenth the price.
Old Apr 22, 2005 | 06:07 PM
Mich6.0's Avatar
Mich6.0
Bighoss550 do you have a cat. coverter, if you do you will be buying a new one because the ATF will clog it solid.
Old Apr 22, 2005 | 06:19 PM
Cowboy Brett's Avatar
Cowboy Brett
I've been using PowerService DieselKleen (Gray Bottle). I don't have enough MPG Data yet to tell you one way or the other, but my idle is quieter now.
I didn't realize about fuel additives until recently. Apparently, a lot of troubles with modern idesels come from the fact that they're designed for higher-quality fuels than the older designs were. I read a lot about carboning up, and folks seem happy with the additives.
I'm going to do a couple of cross-country runs again this summer, and as always, I'll try and get my MPG data up on here at that time.
The two big names bandied about up here on FTE are PowerService and Stanadyne. Both seem to work out well.
Old Apr 22, 2005 | 08:52 PM
bighoss550's Avatar
bighoss550
no cat. but ifn i did, what exactly in atf would plug it? never heard o such a thing
