Exhaust:Form and Function
Old Apr 20, 2005 | 10:48 PM
SoConSick's Avatar
SoConSick
Getting duals put on in early summer but Im not very impressed with the look of the straight out look. To me it seems like they dont fit with the design of the back end of the truck. I want to get it out the side after the tires. What are your opinions fellas? Anyone with pictures of different applications? Keeping in mind form and function of course.
Old Apr 20, 2005 | 11:36 PM
Carguy1959's Avatar
Carguy1959
I was thinking the same thing. But I've pretty much decided to just replace the stock muffler and keep it single. Maybe put a tip on it....
Old Apr 21, 2005 | 01:36 AM
fordmarshall111's Avatar
fordmarshall111
This engine does fine with a single pipe. If you don't know where to run the pipe, just dump it in front of the rear axle. It sounds mean!
Old Apr 21, 2005 | 06:14 AM
WhëëlMå1's Avatar
WhëëlMå1
Well a single side exit will make more power than duals, its a fact. You could check out something like the Gibson Extreme Dual setup. It dumps behind both rear tires.
Old Apr 21, 2005 | 06:52 AM
jaytee04's Avatar
jaytee04
SoConSick, I thought the same thing when i got my truck. But i decided to do it ne way but instead of doing the slanted cut tips, i went with the 4" Rolled Magnaflow Tips which look alot better for the size of the truck. When i got it installed, my feellings tottaly changed. But if u go for something different i would definetly go for behind the tires. That would look nice, but u do have to keep in mind that ur tips will get dinged up from all the rocks that would hit them. (had that problem on my Jeep Rubicon) SO make sure u get stainless steel tips..... Hope this helps.
Old Apr 21, 2005 | 02:50 PM
MommysCrew's Avatar
MommysCrew
Take a look at mine.
