Fe woes
Old Apr 20, 2005 | 09:57 PM
Karm239fh's Avatar
Karm239fh
Unhappy Fe woes
I have had a '63 Galaxie 500 352 2v for about 8 months and have been having a lot of engine woes... I am not very experienced with FE series engines. I have a '52 239 flathead that runs smooth as silk, with no problems.. but I just can't seem to get this FE straightened out. Before I take any drastic measures, I thought I should find out if anyone has similar symptoms and if they just a unique part of owning an FE.
It has new pushrods, lifters, intake & exhaust gaskets, exhaust, exhaust manifolds, valve cover gaskets, electronic dizzy convertion, new plugs & wires, fresh oil & filter, rebuilt carb, etc.
It has a lot of rocker noise, I have replaced all pushrods and hyd. lifters but no luck.
The passenger side exhaust manifold gaskets seem to leak constantly, and the donut gasket will leak occasionally. However, the driver side has not had a single problem.
There is a lot of pinging coming from the exhaust down tubes from the manifolds to the middle of the car (it has new 2" duals) it sounds kinda like rocker noise.. but in the exhaust pipes?
The passenger side exhaust also has what sounds like an exhaust leak... but it isn't a leak, what could it be?
The engine sounds like it is dieseling, very very mildly, but no matter what I do with the ignition or carb.. it doesn't go away.
I feel almost embarrased to be driving it with all these terrible sounds coming from the engine. I can deal with most of these annoyances, but the exhaust problems bugs me the most.
Like I said, my flathead runs like a dream.. if it wasn't for the fan, you wouldn't even know it is running... I've even been able to balance nickles on the intake while running. But this dang 352 has me stumped.
Any help would be appreciated!
Old Apr 20, 2005 | 10:41 PM
rusty70f100's Avatar
rusty70f100
Some questions to start things off:
How do your plugs read?
Are you using the stock non-adjustable valvetrain? If so, did you check lifter preload?
Is the rest of the engine stock, good condition?
Did you run a compression check?
What initial timing are you running? Meaning, when checked at idle with the vacuum advance hose pulled and plugged, what is your timing set at?
When you replaced lifters, did you follow the breakin proceedure? When new lifters are put on a used cam, you need to break 'em in to the cam just like you would with a new cam. 1500 - 3000 rpm for 1/2 hour, slowly varying. Also, did you use plenty of moly lube on the lifters when you installed 'em?
That said, leaky exhaust gaskets are common, and easily fixed. Victor Nitroseal exhaust gaskets seal very well on these engines, and are available at Napa.
Old Apr 21, 2005 | 12:03 AM
Karm239fh's Avatar
Karm239fh
Plugs show slight carbon but not too bad.
Stock non-adjustable valvetrain and did check pre-load.
Engine is stock other than dizzy upgrade and '71 valve covers.
Compression varries 140 to 150 all around.
Initial timing is 6 degrees, have tried 6, 8, 10.
Plenty of lube used for break-in and correct break-in proceedure followed.
The best way I can explain the exhaust pipe pinging is like long tube header noise, but I've never heard of a stock manifold allowing the exhaust pipes to make that sound.
Old Apr 21, 2005 | 01:17 AM
FERacing66's Avatar
FERacing66
As far as the rocker noise goes, make sure you have the special necked bolt in the passage that feeds the oil to the head, otherwise youll wear the rockers out real qucik.
Old Apr 21, 2005 | 07:33 AM
jowilker's Avatar
jowilker
Wonder if the dreaded wrist pin bushing failing, is starting to poke it's head up?
John
Old Apr 21, 2005 | 03:25 PM
Annihilator's Avatar
Annihilator
A bad wrist pin bushing is very tough to diagnose, I believe that there are some procedures that can narrow it down though in the Steve Christ book.
