how to check tps
Old Apr 20, 2005 | 09:47 PM
redneckf350's Avatar
redneckf350
how to check tps
how do you check to see if tps is in range? 94 f350 7.3L idi e4od
Old Apr 21, 2005 | 05:41 AM
trike1946's Avatar
trike1946
Do a search in this forum, using just TPS. About halfway down the page you will see a thread called TPS adjustment/replace. I think it is from 2-21-05. Look in there and you will see instructions from PLC7.3. If you have a meter it is easy to do. Good luck with it.
