engine and trany swap
Old Oct 1, 2000 | 07:38 AM
het_fan's Avatar
het_fan
i have a rotted out 79 f100 that has a rebuilt 302.i want to put the motor and trany in my 82 f100. my 82 has a 300 with a standard trany.can any one tell me if the trany cross member and drive shaft will fit in the 82 thank you
mark
Old Oct 2, 2000 | 10:17 AM
deleontow's Avatar
deleontow
The motor and tranny will swap right accorss. You will however have to change the trans linkage, as 80 up uses a different linkage. Take a look at the lever on your trans and the newer one to see if they are the same.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old Oct 2, 2000 | 10:34 AM
maveric's Avatar
maveric
