heads
Old Oct 4, 2000 | 12:18 AM
jack83's Avatar
jack83
heads
I took the heads off and did not mark which was left or right. does it make a difference or can you swap sides or are they marked a certain way?
Thanks.
Old Oct 4, 2000 | 12:03 PM
frankenstein's Avatar
frankenstein
heads
In most cases it will not matter. However onee thing to look for when replacing is, if you have anegr tube that runs from one side to the other that you have the heads facing correctly. one side will have treads for accesories the other will not.
Old Oct 4, 2000 | 01:38 PM
slikness's Avatar
slikness
heads
The air tube runs all the way thru the head, but the front of the head normally has a threaded insert that plugs the front of the tube and allows you to attach accessories to the front of the head. I have those inserts in the front and back on my 351W and have eliminated the air tube.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Oct 4, 2000 | 06:59 PM
mrfixit's Avatar
mrfixit
heads
