retro 302 timing
Old Apr 19, 2005 | 07:51 PM
krautwolf's Avatar
krautwolf
retro 302 timing
In my "59 F100 Panel I've got an 84 Towne Car 302 that I've stripped of all emissions stuff except the PCV valve. Added Duraspark II ignition/distributor, Edelbrock Performer intake manifold and replaced the Ford TBI with a Holley Pro-Jection System. Am experiencing backfiring through the exhaust when deccelerating. I suspect it's timing but am somewhat confused by what year's setting to use. The Haynes manual says the 84 Lincoln 302 setting is 10 BTDC, but that the 1980 - 83 carbureted models' setting range from 6 BTDC in '80 to 10 in '83. Currently set at 8 and runs well except for the noise when deccelerating. Will check intake manifold bolts & exhaust too. I prefer to call on your experience before trying trial-and-error.
