I found a set of headers i want to get for my truck, the guy has them listed as Bronco headers but wouldnt they fit a F-150 too? He said they are for a 351/400 motor and thats what my truck has. Also can i use them with my A/c? For $115 shiped i dont think i can go wrong.
I put a set of hedman headers on my pickup. My trucks 4wd I'm not sure if it matters or not. I don't see where it would matter about the a/c. Thats a good price too.
Yea my truck is a 4x4 too, Do you like the headers? I think it would be alot better then trying to run them under the truck and having to put the pipe under that huge cross member where it would get smashed. Plus exhuast would be very easy to run off them.
I like my headers and on my truck you could tell the difference in the performance. I don't quite understand why they don't come with at least the collectors. The fender-well exit will keep the exhaust out of the if you need to take the starter off or anything else you might need to do. For my exhaust I put purple horney header mufflers. Which makes my exhaust all of 3 feet long. Sounds Great.
Ive got a set of extra collectors and gaskets from my mud truck since im runing open headers on it that should work on these headers. Ive got a set of 2 1/2" Purple horney glass packs ill probly put on there and just run it past the cab for awhile then finish it out with a tip coming out in fornt of the rear wheel.
I got the new headers today, look really good. The guy sent me colletors, bolts and gaskets with it. Ill tell you guys how they are when i put them on saturday morning.
