1978 - 1996 Big Bronco
Computer Upgrade or?
Old Apr 19, 2005 | 11:04 AM
Herc 5HP's Avatar
Herc 5HP
HI,
What I have is a 1990 5.8L.
Q#1; Is there a computer upgrade or something I can do to this computer to give it a little more poop?
Q#2; What steps are needed to set or check the timing? Does anyone have a picture and instructions?
Q#3; Maybe someone could help me on where I could look for a leak. This engine has 10K on a rebuild, and had an oil and water leak on the back of the engine. The place that rebuilt it said there is nothing wrong (how can a shop get away with this). I have looked and narrowed it down to the back of the engine. You know how tight things are on a 5.8L and automatic, so any ideas?
Thanks, Keep on Bronco'n
Herc 5HP
Old Apr 19, 2005 | 11:38 AM
greystreak92's Avatar
greystreak92
1) Yes, there are aftermarket chips available for improving performance but they are not cheap.
2) To set the "base timing" you have to warm the engine to opertatiing temp. Shut it off. Remove the SPOUT connector. (Check the red link in my signature for info as to where it is and what it does). Restart the truck with a timing light already connected. Check the decal under the hood but, the base timing should be about 10-12* BTDC. Adjust as necessary by loosening the distributor clamp bolt and rotating the distributor. Once proper base timing is set, retighten the clamp bolt, disconnect the timing light and re-install the SPOUT connector. DONE.
3) If the leak is BOTH oil AND water from the same area, Id' suspect the rebuilder damaged a head gasket when installing them. The only other location that water might leak is at the very back of the lower intake. There is a coolant cross-over port in the lower intake that connects the left and right cylinder heads if the lower intake-to-cylinder head gasket has a problem, it can leak here.
Old Apr 19, 2005 | 08:14 PM
Herc 5HP's Avatar
Herc 5HP
I just got the renewal notice, and I have to have it smogged. Will this hurt the outcome of the test, I'm in California.
I understand that CRC makes a product called "Guarantied To Pass", what do you think about that stuff?
Thanks
Herc 5HP
c130herc
Oct 27, 2017 04:24 PM
speedemon1084
Aug 14, 2015 12:19 PM
SideWinder4.9l
27
Sep 26, 2011 11:21 PM
rwhite07PSD
1947 and Older Ford Trucks
May 10, 2009 12:10 PM
freeky1
Sep 14, 2002 01:03 PM
