Sponsored by: Innova
Sirius Hookup Questions
Old Apr 19, 2005 | 10:55 AM
02superstroker's Avatar
02superstroker
I picked up a sirius system from someone, that uses a kenwood FM modulator deal. Everything is self explainatory in the install except for three wires. These three wires come from the Kenwood FM modulator box deal and hook up somewhere into the radio wire harness. They are labeled as power inputs, and are three colors.. blak, yellow, and red. Does anyone know what wires these splice into? Truck is 02 f350. Thanks.
Old Apr 19, 2005 | 11:00 AM
cgl's Avatar
cgl
Is this the stock head unit?? The black is for the ground, yellow for constant on (battery), and the red for switched power input. You should be able to find the right factory wires by using a test light... or I can check how mine's wired and get back to you... I don't have the factory colors memorized.... yet
If you had an aftermarket HU, the correct wires should be easy to identify.
__________________
2002 F-350 XLT 4x4 PSD 6spd SC SB SRW
2001 400ex SportTrax
Polaris 800 RMK
1990 F-150 Lariat 4x4 I-6 5spd RC SB
---Also in Family---
2003 F-250 XLT FX4 6.0PSD TSA SC SB
2001 F-150 XLT 4x4 5.4 AT SC SB
Old Apr 20, 2005 | 04:11 PM
02superstroker
Ok I got the Chilton's book on the truck, so I know the colors and what each wire is for coming from thee back of the radio... but...
...When you say "switched power input" what do you mean? There are several power wires going into the radio, a ground, a constant hot, a hot when the key is on, and also one for illumination. What do yall think?
Thanks!
Old Apr 20, 2005 | 04:16 PM
JERRY'S PSD's Avatar
JERRY'S PSD
switched is when the key is on
Old Apr 20, 2005 | 09:11 PM
02superstroker
Thanks guys
