Does anyone that has a 2005 SD with the 18" rims know what the wheel width is? I have one on order and was just curious what possible tire options could be. Thanks
I believe they are 18"x8" and most likely will come with Contitrac TR M&S LT275R70x18 Tires rated at 3640lbs "E" @80psi \\
I may be off a little on the specs but not much
Finding comparable other tires is a serious challenge as most are class "D" between 2600-3400lb rated at max psi. OK if you never tow heavy but not any good at all if you expect to use the truck to near max rated tow haul capacities.
