Door Panels
Old Oct 13, 2000 | 07:38 AM
robert_boyd's Avatar
robert_boyd
Door Panels
My 1986 F-150's door panels are flaking on top. I've looked at the replacement panels that can be ordered from JC Whitney. Has anyone had any experience with them? I have also seen a plastic paint type coating that can be sprayed on. Anybody tried it, does it work? Which is best?
Thanks,
Bob
Old Oct 13, 2000 | 08:22 AM
AlM's Avatar
AlM
Door Panels
I heard from many others that the JC Whitney panels are not so hot. zIf you look at the pic in their catalog, you will see screws that attach them to the door frame. Maybe someone found other panels that fit like the originals.
Old Oct 13, 2000 | 09:26 AM
slikness's Avatar
slikness
Door Panels
Old Oct 13, 2000 | 10:47 AM
maveric's Avatar
maveric
Door Panels
As with almost every JC Whitney product, they don't fit right. The paint idea isn't a good idea either. I have painted interior parts, but it is a PITA, and usually doesn't stick very well.
I have a friend with a 98 F-800, and the cab is identical to my 82 F-x50. The dash and the door panels looked identical to mine, so I think Ford is still making them. You might check with a local dealership to see. They will be more pricey than the JC Whitney ones, but you will be more happy with them.
Let me know if this will work.
Chris
cmercer@auxserv1.unco.edu
http://www.mountaineers4x4.org/mercer
'82 F-350, '53 Dodge PU, '85 4Runner
Proud enough to stack hay, crazy enough to eat it.
