4x4 / transfer-case not engaging?
I've searched this forum, and found a lot of info, but not quite what I need to fix it. Below are some specifics about my Bronco-Problem:
- There is no clicking, or any noise, when I press the 4x4 button.
- I pulled the actuator motor on the transfer case to see if maybe jarring it a bit might help.
- I checked the connections at the actuator motor, and everything looked good.
- I removed the kick-plate at the passenger-side floor to check, what I think is, the controll module. After following one of the write-ups found on FTE, I removed one of the plugs on the bottom of the module, then pressed the little, square, white button - that caused a "constant", "non-blinking" LED. I think the write stated that a "constant" LED meant the module was bad (?).
Thanks in advance for your help!
