Engine ran radically, WILL NOT START
Old Apr 18, 2005 | 10:31 AM
Jerry ranger9's Avatar
Jerry ranger9
Engine ran radically. 2.9 lit. ranger, fuel injected, 5 speed. What transpired, I had just driven for 20 minuets, on belt way to heat it up to temp, ran good no problems. Stooped to shop for 1 hour, when I started it up it started to knock hard and shake, oil pressure dropped, and the lifters rattled radically not just tapping. I drove it for ten miles on and off it would get better and worse but never returned to full power. Now it will not start, wants to fire up, one or two cylinders fire. I have disconnected the exhaust so it is not the cat, checked the wires acceptable resistance, added new plugs, plan to check the rest of the ignition system but could it be in the fuel distribution system, like maybe a clogged filter, injector problem or a leak, any ideas or experience? any help appreciated.
Old Apr 19, 2005 | 07:49 PM
Ken00's Avatar
Ken00
WIth all the noise/oil pressure stuff I would start by checking compression.
