Texas Chapter Join Chapter, Leader: LibTimothy
Help! Engine Stops Without Warning
Old Apr 18, 2005 | 07:39 AM
Cicobra's Avatar
Cicobra
Without warning, the engine immediately stops while driving; then it begins running again without engaging the starter. I never know when this will happen. Purchased re-built Carb one year ago; new fuel filter; idles smoothly; no misses. Doesn't happen all of the time. Anyone ever had similar problem? Thanks in advance.
Old Apr 18, 2005 | 10:34 PM
King Triton's Avatar
King Triton
How about a little more info,what year is it? what engine size?
Old Apr 19, 2005 | 06:50 AM
Cicobra's Avatar
Cicobra
1984 F-150; 302 cu. in. .
Old Apr 19, 2005 | 07:55 AM
King Triton
Well,due to the fact that you say it dies immediately,I would look more toward an electrical problem than a fuel problem.With a fuel problem it would usually cough or sputter or lose power while dieing,but an electrical problem in your primary ignition circuit would cause an instant off situation.So,the first thing I would check would be the connectors at the distributor and the coil.
Old Apr 19, 2005 | 09:06 AM
Cicobra's Avatar
Cicobra
Ok. Thank you. I'll check it out.
Old Apr 21, 2005 | 11:55 PM
rlmdad's Avatar
rlmdad
Agree with King Triton, your problem is more than likely in the ignition system. Not familiar with the ignition system of an 84 F-150, is it electronic or do you have points? Used to have an EXP that died like that but had to cool before it would restart. Ended up being the magnetic pickoff in distributor would fail when hot. Just a thought.
Ron
Old Apr 22, 2005 | 05:40 AM
ol yeller's Avatar
ol yeller
Chech all the grounds. they may look good but make sure thry are good and clean.
