need help!!
Old Apr 18, 2005 | 12:05 AM
mikeslate's Avatar
mikeslate
need help!!
I was out off roading and when i got out i noticed i was leaking fluid from the rear end. Come to find out, the pumpkin had a hole in it like some gearing broke right through it. The truck is still moving perfectly, the only problem is this hole in the rear housing of the pumpkin. When i take the rear cover off what kind of damage should i look for or expect? Not certain on what or why this happened. Any advice???
Old Apr 18, 2005 | 12:24 AM
Racerguy's Avatar
Racerguy
Hi and welcome to FTE
What year and model are you working on?
Does it a limited slip rear diff?
Is the hole from the inside out?
Old Apr 18, 2005 | 01:38 AM
mikeslate's Avatar
mikeslate
It's a ford 2000 F150 2wd 4.6 with a 8.8 transmission which i rear gear to 4:56, it is limited slip and the hole is from inside to out..
Old Apr 18, 2005 | 09:13 PM
Racerguy's Avatar
Racerguy
I've seen pieces of limited slip clutch blow out the cover, also pieces of gears.
Hopefully when you get the cover off you don't find anything toooo serious
Old Apr 18, 2005 | 09:28 PM
mikeslate's Avatar
mikeslate
thanks for the advice, im hoping thats it, if its the limited slip ill just replace it all with positive...the truck still goes along so im thinking that could be it....
