Delay Wipers Question
Old Apr 17, 2005 | 10:04 PM
Rintin69's Avatar
Rintin69
I tried searching for this subject but it kept coming up as an error. I know this has been talked about here, but I couldn't find it. Here is my issue, I have an 82 Ford F100 that came with just the two speed wipers. I have a 91 Ford parts truck that has the delay wipers. I pulled the switch assembly out of both and switched in the the delay switch. I only have high speed but the wipers are actually going slow. Is there another piece that I missed or could it be a bad switch? Thanks
Old Apr 17, 2005 | 11:39 PM
yozsi's Avatar
yozsi
yes, you also have to include the delay relay too.
Old Apr 18, 2005 | 12:25 AM
RR4E's Avatar
RR4E
If you follow the harness back from where the switch plugs in, in your parts truck, there will be a black box in the harness. It's required(it's the delay relay box) to make the delay feature work.
Old Apr 19, 2005 | 07:53 PM
nsshull's Avatar
nsshull
Make sure it works, that box is fried on my F250.....so is the switch....called the dealership, somethinl ike 300 bucks canadian to get it replaced:|
Old Apr 19, 2005 | 08:23 PM
Beast12's Avatar
Beast12
Maybe this will help?? https://www.ford-trucks.com/forums/s...ighlight=delay
-Matt
Old Apr 19, 2005 | 08:53 PM
CdnFord Eh's Avatar
CdnFord Eh
Make sure you have the black box from your parts truck, that is the delay. There is also a extra ground wire that has to be connected from the switch. If you do you have a bad delay setup, you can pick one off of ebay cheaper than the dealer.
Old Apr 21, 2005 | 01:10 PM
kucerakk's Avatar
kucerakk
I also had the same problem on my 84 F250 and it ended up being the ground wire on the relay that was loose. Fixed that up and everything was fine.
