Sponsored by: Auxito
F-150 problem
Old Apr 17, 2005 | 08:46 PM
dog2580's Avatar
dog2580
F-150 problem
Okay here it is...I got a '99 F-150 4x4 that has a squeak noise coming from the rear (assuming the brake) sometimes it doesnt happen until you maybe drive about 10 miles or so, but when you brake it tends to get louder then quieter as you take off, sounds kind of like the brake may be dragging, any thoughts would be appreciated.
Old Apr 17, 2005 | 08:55 PM
peppermrj's Avatar
peppermrj
do you have rear disc brakes?
Old Apr 17, 2005 | 08:58 PM
dog2580's Avatar
dog2580
Yes it does have rear disc brakes
Old Apr 17, 2005 | 09:15 PM
Glock's Avatar
Glock
You need to inspect the brakes pads and see if the ware tab is rubbing on the rotors. If it is replace the pads.
Old Apr 17, 2005 | 09:43 PM
peppermrj's Avatar
peppermrj
My thoughts also. The wear sensor is only a small metel tang attached to the back of the pad. It is bent toward the front of the pad and rotor. It is supposed to contact the rotor before the brake pads are history. It is ususally sqealing when the brakes are applied and quite when the brakes are released. Some pads have them others do not. Check for the sensorand pad wear. Sometimes the sensor is positioned improperly (bent) and sqeal pematurtely.
Old Apr 17, 2005 | 10:32 PM
LxMan1's Avatar
LxMan1
You may want to check the parking brake too. It is a drum brake inside of the rear rotor.
