tranny fluid leak
Old Apr 17, 2005 | 08:17 PM
jcab's Avatar
jcab
tranny fluid leak
Has anyone had a leak of trans. fluid at the dip stick where it inserts into the transmission?? I cleaned the oil off with engine cleaner and found the oil coming from that area. If you had this problem, how did you fix it?? I hate leaks of anykind. Thanks in advance Jeff
Old Apr 17, 2005 | 08:44 PM
stuart1's Avatar
stuart1
Usually an "O" ring is all that is needed.
I have seen filler tubes crack around the "O" ring area.
Old Apr 17, 2005 | 11:20 PM
jcab's Avatar
jcab
Thanks for the reply, I will fix it when I install sonnax valve and tricumulator springs. Jeff
Old Apr 19, 2005 | 11:59 PM
jcab's Avatar
jcab
An afterthought to your reply about cracked dipstick at the transmission. I installed the 4 inch exhaust an remember having a rough time with downpipe install around that area and believe it is cracked. What would you suggest to fix it?? Drain trans and reweld, seems like an awfull lot of work to repair a nuisance of a leak. Any ideas would be appreciated? Thanks Jeff
Old Apr 20, 2005 | 07:36 AM
stuart1's Avatar
stuart1
It is a very thin area to weld properly.
Quite often a transmission shop will have a replacement tube just for this.
It is a tube about 4" long. You cut yours off and stuff it inside the new portion.
Works good too.
Old Apr 20, 2005 | 05:45 PM
jesse460's Avatar
jesse460
I bent mine and had to replace it, If I remember right it was only around $30 at the dealer for a new tube.
