Throttle Position Sensor
Old Oct 24, 2000 | 11:01 AM
huskeyone's Avatar
huskeyone
I am having bad luck with the "throttle" areas of my 67F250 and 93E150 ClbWgn.!!
The van will run ok, and then after several miles she shifts hard from 1-2nd, and 3-4th?(E4OD trans.) I ran the codes on it and I am getting a 121, which has something to do with the Throttle positon sensor not having consistant voltage? Should I just replace this?
Oh yea, not sure if she's a 351 or 302, engine type in VIN is H??
Thanks for any info!!!
John Hammell
93 E150 ClbWgn.XLT
67 F250 352
Old Oct 24, 2000 | 06:03 PM
Pastmaster's Avatar
Pastmaster
It is exactly under the aluminum end of the tb, right at the bottom, it''s small and round, black. As far as a difference between the 2 (302 and 351), I can't tell. The 302 is a 5.0L and the 351 is a 5.8L
Pastmaster's 1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
Old Oct 24, 2000 | 10:43 PM
PAUL_2's Avatar
PAUL_2
Engine Code H is a 5.8L / 351 Cu In .
Old Oct 24, 2000 | 10:49 PM
fordson's Avatar
fordson
