What does "flash" mean? I've seen it refered to the tranny and the engine, but have no idea what you are talking about. What are the pros and cons of having it done? How do you know it needs to be done? Bought my 6.0 last November (new) and living up here in Alaska I use 4 wheel drive almost constantly, mainly highway driving and run the winter blend. I've been averaging about 17 miles to the gallon. Does this sound good. I don't really notice any problems with my truck, though I did get my recall notice about the pinion shaft coming loose and causing (my favorite<tell a liar(lawyer). wrote this) "metallic particle contamination" and had my transfer case lever pop out fixed. Thanks for the input and help.....
some of the 6.0's computer programs have problems...a flash is supposively sopost to "make it better". but i had it done on my 04 and it made it worse! what ever you do dont get urs flashed
Now really: It means to erase your current modules programming (it generally is done to the PCM - Powertrain Control Module) and replace it with the latest calibration
The calibration can be there to improve many things, and unfortunately in the same process it can make other things worse.
If you are happy with your trucks performance I wouldn't worry about it, 17mpg sounds pretty good, especially with winter blend.
