CD player installation
Old Apr 16, 2005 | 09:27 PM
Mestrell's Avatar
Mestrell
Hello everyone,
I have a 78 Ford F250 (460 4 barrel). I want to replace the radio with a CD player. I need to get a special mounting bracket that will replace the old bracket, which included the heater controls. Does anyone know of a product that is available as a replacement for the stock radio and heater control bracket than can accomodate a CD player?
Any info is much appreciated.
Thanks
Old Apr 16, 2005 | 10:25 PM
30over's Avatar
30over
I am into this myself. Try searching CD player to read some previous posts. I plan on modifying the one in my truck and add a piece of sheet metal to it if I need too. I don't think there is any aftermarket mounts but, there might be. Good Luck!!
Old Apr 17, 2005 | 01:40 AM
Cornbread's Avatar
Cornbread
check my gallery. i have some pics of mine. i used a sheet metal patch pannel from my local auto part store. i cut and bent it to the right shape to follow the dash. used jb weld to fill the seams smooth and to hold it. i used very fine sand paper to smooth it. i also used wood strips on the back side that i jb welded the pannel and existing dash for support. sounds kinda redneck i know but it looks factory. take your time. jb weld holds very well to plastic and it is a pain to cut it back out if you screw up. cut and fit over and over till it is to your likeing.
if need be i will post close up photo's upon request
i am possitive you can come up with better ways. a friend is using fiberglass to do his.
Fordby4
20
Aug 26, 2010 02:03 PM
blindguy
Jul 11, 2006 03:26 PM
Poulsom
Apr 23, 2006 08:49 AM
tys78
Oct 4, 2004 01:33 PM
cornwall
Dec 28, 2003 09:10 AM
