Need locknut/wheel hub help bad
Old Apr 16, 2005 | 03:26 PM
HillbillyHellcat's Avatar
HillbillyHellcat
I borrowed a socket from someone, took the wheel nut off, took the rotor off, cleaned everything up and put the new bearings and seal in and put the rotor on. Now I have no idea how much torque the locknut needs, but I tighten it to 160 (I read that somewhere, and now realize that is wrong). At 160, the wheel is pretty hard to turn, but turns smooth. Then I realize the hub mechanisms have seperated from the locknut. I go to put it back on, and realize the neck of the locknut has mushroomed out and cracked. Now I need a new locknut. I've also noticed that the gap between the splines and the threads for the locknut is gone, and there is no place to put the washers and the C clip. Any ideas what happened? How much torque should I have used on the locknut? What has happened to the gap between the threads and splines? This is for a 97 ranger w/ auto hubs. Any help would be appreciated. Thanks.
Old Apr 16, 2005 | 04:05 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Did you fully seat the bearing race on the inside bearing?
On the torque, I flat out ignore the Ford service method and instead tighten the nut to maybe 15 ft-lbs and rotate the rotar in each direction several times. I repeat this until applying additional torque results in no additional nut tightening. Rotation of the rotor will be "snug", but not overly tight. It will loosen a tad after you dirve it a bit. The idea is to remove any play in the bearing and have just a bit of preload on the nut/spindle.
Old Apr 16, 2005 | 05:24 PM
HillbillyHellcat
Thanks for the help. I just put the locknut back on without the hub assembly and later this week i'm gonna pick up a hub and locknut at the local junkyard.
