302 "PING"
Old Apr 16, 2005 | 09:48 AM
newr's Avatar
newr
Exclamation 302 "PING"
Howdy
I have a '82 F150 302 that starts and runs just fine. Accelerates strong, no noticable oil in the water or water in the oil, good tuneup parts, etc.
The one drivability issue that it has is a highway speed ping. It isn't real strong above above about 50 mph and at 60 the ping starst to show up.
A couple questions:
1)The PO put a small Carter 4BBl on it and I don't know how it's set-up internally, float height, jets etc. Could pinging be the result of mix or starvation?
2) The PO also had the timing all messed up. I set it by vacuum to get the best start and acceleration and I'm wondering if I have it a tad too far advanced.
Thanks in advance.
Ron
Old Apr 18, 2005 | 10:33 AM
ronclark's Avatar
ronclark
Either or. could be either one. Lean conditions cause spark knock. High timing causes spark knock. Carbon in the cylinders causes spark knock. If you set the timing by vacuum and not with a light then thats where your problem most likely is located. Try setting with a light or lowering the timing 2 degrees at the time until the spark knock goes away and see how far you have to go.
x_man586
15
Jan 2, 2014 09:23 AM
pidaster
Aug 30, 2011 06:43 PM
Bigred77
May 13, 2003 07:11 PM
warren
Jul 21, 2000 10:12 AM
Sam
Dec 17, 1999 06:17 AM
