Transmission ratio?
Old Oct 31, 2000 | 10:16 AM
tom87's Avatar
tom87
Transmission ratio?
Old Nov 1, 2000 | 09:36 PM
hecticgb's Avatar
hecticgb
Transmission ratio?
Im trying to figure out what gear ratio my transmission has? Trans code is K if that helps.
I have a '87 F250 300-I6. Rear ratio is 4.10..
Thanks,
Troy
Old Nov 1, 2000 | 11:41 PM
PAUL_2's Avatar
PAUL_2
Transmission ratio?
Trans Code K I beleive is the C6 . Cant help you with the gear ratios .
Old Nov 2, 2000 | 08:30 AM
TallPaul's Avatar
TallPaul
Transmission ratio?
I believe that automatic trannys generally run (with some minor variation of course) about 2.50 ratio in 1st, 1.50 in 2nd, and obviously 1.00 in third. Don't know about the overdrive. Do as I did and call Ford service departments. A couple told me they were to busy to deal with me but finally one gave me the ratios for my Mazda 5 speed.
