1978 - 1996 Big Bronco
wiring harness
Old Apr 15, 2005 | 03:00 PM
frankle8's Avatar
frankle8
Question wiring harness
I need to change out the entire harness in my '88 XLT. It has a 351W. I have found a complete EFI harness from a '89 XLT, but with one exception, it had a 302 in it. My question is, do you forsee any problems with the harness out of the 302 working with my 351? Would everything hookup as normal or would modifications be required? Any info anyone can give will be appreciated.
Old Apr 15, 2005 | 03:19 PM
Kemicalburns's Avatar
Kemicalburns
it will work just fine. i had an 88 302 and swapped in a 5.8 and reused my 302 harness. might have 1 or two connections that go nowhere but thats it
Old Apr 15, 2005 | 09:33 PM
Trublufords's Avatar
Trublufords
A quick look at a 88 Bronco EVTM and a 89 Bronco EVTM might be a good idea though.(electrical -vacuum -trouble shooting manuel from FORD)Look at 88 5.8 section then compare to 89 5.0 section.
Old Apr 18, 2005 | 08:50 AM
Kemicalburns
the vacum lines all go to the same places on either motor. some lines might be shorter on the 302.
Old Apr 18, 2005 | 09:36 PM
Trublufords
I thought he was more concerned about the wire harness??
