86 f-150 4x4 Having problem
Old Nov 4, 2000 | 11:16 PM
billg's Avatar
billg
with gas gauge. Does not work, what is the easiest thing to check first. Then go in order other things that can be the problem. Will I have to drop tank? Thanks for the help
Old Nov 5, 2000 | 12:12 PM
pita's Avatar
pita
The first and easiest thing to do is find the wire going to the gauge and ground it if the guage goes to full then your guage is working if it doens't move the its not working if the guage is working then your prob in the sending unit which you will have to drop your tank to replace, a common prob with those is the float gets a hole in it and doesn't work so all you'll have to replace is the float and not the entire sending unit
Old Nov 5, 2000 | 01:58 PM
FTE Ken's Avatar
FTE Ken
