rocker arm question
Old Apr 14, 2005 | 11:15 PM
bigblocksix's Avatar
bigblocksix
rocker arm question
hey everyone, im puttin together a 351w right now, its got .030 stock replacement pistons (fresh bore), 93 mustang maf injection, melling performance cam with .461 lift. i was looking for some roler rockers but the only pedestal mount ones i can find are from crane cams and have a 1.7 ratio, will i have any valve clearence issues with that much lift and stock pistons?
Old Apr 15, 2005 | 08:16 AM
ronclark's Avatar
ronclark
The 1.7 rockers should work just fine. You aren't running a high enough lift to hurt.
Old Apr 15, 2005 | 07:47 PM
baddad457's Avatar
baddad457
Make sure your heads will work with those rockers too. If you don't have pedestal mount heads ( 78-97) they won't work. The 1.7's increase the lift specs by only .030, not hardly enough to matter unless you have a big *** cam to start with.
Old Apr 16, 2005 | 02:54 AM
bigblocksix
thanks guys, their e7 heads so they are pedistal mount
Kyle Wood
Nov 12, 2016 12:48 PM
Kyle Wood
Nov 4, 2016 02:15 PM
Kyle Wood
Nov 4, 2016 08:43 AM
Shadow944795
May 22, 2015 01:23 PM
79supercab4x4
Mar 8, 2002 01:04 AM
