dumb question
Old Apr 14, 2005 | 08:05 PM
66f100352's Avatar
66f100352
dumb question
Do I adjust the carb to 1500 when it's cold or 1500 when it's hot for the cold idle speed? As in when I first start it should I then adjust it to 1500 or do I let it fully warm up then kick on the high speed cam and then adjust it to 1500? Thanks
Mark
Old Apr 14, 2005 | 11:03 PM
LxMan1's Avatar
LxMan1
you need to adjust the fast idle screw to 1500 when cold and the choke is on. It is the screw on the passenger side under the choke on the linkage. It should only idle about 750 rpm hot with the choke open.
