Another back up light problem
Old Apr 14, 2005 | 07:54 PM
79'F-250_Guy's Avatar
79'F-250_Guy
Question Another back up light problem
my back up lights don't work i adjusted the switch and i know that that works. Im gunna have the trace the wires back. but my question is does anyone know where i can go on line for a wiring diagram. i think that might make it a little easer.
(Also check out my truck pics and leave a comment )
Old Apr 14, 2005 | 08:56 PM
Mil1ion's Avatar
Mil1ion
Remove the switch & clean it out thoroughly:
first with lacquer thinner & follow up with Electrical cleaner.
Then grease the bearing with Lubriplate > plug it in & test it before installing it.
Then be very precise when installing it.
Place gearshift in neutral > Transmission in Neutral <> Switch in neutral with drill bit through hole.
See bottom right corner of this page.
http://www.clubfte.com/users/mil1ion...strations.html
