1978 - 1996 Big Bronco
installing a ES2000 Steering Stablizer Need Help
Old Apr 14, 2005 | 05:44 PM
tygarcia's Avatar
tygarcia
Just never put one on before but I know I can, does anyone know of a step by step link. Or can you explain where the proper place to install it at. All I need is a good picture for me to see how it goes. Thanks for your help! Going on a 1982 Ford Bronco
Old Apr 14, 2005 | 08:53 PM
greystreak92's Avatar
greystreak92
Where ever you want to put it is pretty much fine. Its not going to do much for you with the TTB (Twin Traction Beam) front end since there is no true drag link with the OEM steering setup. The "inverted Y" steering linkage on the TTB trucks still suffers from bump-steer even with a stabilizer because the tierods end up out pf phase with the axle halves. If you are dead set on installing it, make sure it gets attached to the tierod that actually connects to the pitman arm. The difficulty you are going to run into is the fact that adding the stabilizer will actually hinder your suspension travel unless you can figure out how to mount it to the passenger side axle half (same half that has the tierod that attaches directly to the pitman arm on the steering box).
