beemernut dc-10 is a super consentrate. mixed with water 1 gallon makes about 30 gallons. i mix it 50-50 to degrease engines best thing i have found to clean anything from greasey clothes to garage floors made by accu-prep corp. it is a industrial cleaner sold in bulk 55 gallon drums. my brother-n-law owns the company so i can buy it by the gallon. i used it to remove smoke damage from a fire it was the only thing i could get that would remove it took the smoke stain and finish off the wood cabnets i was cleaning all i had to do was rinse off and re-polly
Master cylinder, carb, alternator, power steering dipstick/filler, transmission dipstick/filler, dizzy, battery top, starter if it were mine. I would rather use paint thinner and air syphon gun, no rust. JMO.
7fords, thanks I learned something today besides punching the emergency brake as a cop was up our rears and the guy next to me got the ticket. Eats paint, was it latex or oil base? Thanks.
beemernut the finish on the cabnets was the old varnish type dc-10 isnt toxic to breath but you have to wear rubber gloves when you use it because it will remove the oils out of your skin causing your hands to dry out and crack real bad
