Steering question
Old Nov 15, 2000 | 08:53 PM
whaynes's Avatar
whaynes
Steering question
I just finished replacing the Sector shaft seal to stop a leak from the gearbox...It appears to have corrected the problem. My question is, do I have to re-dial in the power steering adjustment screw as per the Haynes manual or should I be ok without it? The steering wheel seems to still have the same position.
Thanks,
WHaynes
93 F150 4.9L 4x4
4" ProComp StII Lift
BFG 33in 4.10's
Detroit TrueTrac's
Old Nov 15, 2000 | 11:04 PM
PAUL_2's Avatar
PAUL_2
Steering question
As long as the steering isnt too tight or too sloppy then Id say you should be Ok .
Old Nov 16, 2000 | 12:47 AM
Superdave's Avatar
Superdave
Steering question
