9"
Old Apr 13, 2005 | 09:38 AM
blockheadbob's Avatar
blockheadbob
Question 9"
I have a 28 spline 9" rear end in a 78 F-150 and I was wondering if I can upgrade to a 31 spline, and what do I have to change? My ring and pinion are shot and there is quite a bit of wear on the splines.
Thanks,
Bob
Old Apr 13, 2005 | 09:44 AM
beartracks's Avatar
beartracks
You will need axles and a "pumkin". You probably need bearings and seals anyway and the gears have to be set up by someone with experience. So that's not gonna be cheap unless you can canibalize another truck for the parts. If you can find a donor in good shape it would be much cheaper and just a matter of bolting in the parts.
Old Apr 13, 2005 | 02:16 PM
Mil1ion's Avatar
Mil1ion
That's weird from what I thought, most trucks came with 31 spline.
Cars usually had the 28's.
Old Apr 13, 2005 | 02:23 PM
beartracks's Avatar
beartracks
Mine came with 31 but I've heard others have 28. Not sure what the criteria was.
Old Apr 13, 2005 | 02:55 PM
79schaefer's Avatar
79schaefer
The "general" rule is that 2wd had 28 spline and 4wd had 31 spline. Like anything with these trucks tho, things are subject to change at any givin moment
Steve S.
To many to list
Old Apr 13, 2005 | 03:32 PM
savage066's Avatar
savage066
i think that's correct...my '79 is 28 spline as well.
Old Apr 14, 2005 | 11:16 AM
blockheadbob
Thumbs up
Thanks for the input. My trucks rear end has probably been replaced at one time or another.
Bob
Old Apr 15, 2005 | 12:56 AM
red '73 F-100's Avatar
red '73 F-100
My '73 F-100 HAD a 28-spline 9"; it came with a 302. I used 31-spline axles and third-member out of a '74 F-100 with a 400. I also have a '79 SWB parts truck with 28-spline axles, but it came with a 300.
Old Apr 15, 2005 | 12:28 PM
RTM's Avatar
RTM
Most of the truck axles I have ever pulled have been 31 splines. I have pulled a couple van axles that had 28 spline axles but the last two vans had 31 spline axles. I have yet to pull a 28 spline axle from an F150, F100 yes.
Amphihauler
Oct 1, 2016 07:54 PM
greentruck72
May 20, 2015 03:13 PM
Swagtastic
Dec 24, 2011 09:23 PM
JakeHan
Jul 6, 2005 07:44 PM
superswamper
26
Apr 25, 2003 05:20 AM
