Offroad & 4x4
custom crossmember
Old Apr 12, 2005 | 08:07 PM
bigdaddy25's Avatar
bigdaddy25
custom crossmember
Has anyone built a custom crossmember to lower your tranny/tcase. If so what size of either plate steel or tubing did you use and do you have any pics? Thanks
Old Apr 12, 2005 | 08:37 PM
ramboss429's Avatar
ramboss429
I'm building crossmembers this week once I get my throwout bearing. I am either gonna use Channel Iron or something else, so I'd like to hear other peoples thoughts on this too!
Old Apr 12, 2005 | 08:55 PM
fishmanndotcom's Avatar
fishmanndotcom
i used 1/2" plate bolted to the inside of my frame. its not the trickest but it holds up fine!
-cutts-
Old Apr 12, 2005 | 10:00 PM
rebocardo's Avatar
rebocardo
1/4 wall tubing or 3/16 channel. I prefer 3/16 channel. If you cut and weld 3/16 channel (because the web itself is at least 5/16) it will pretty much hold anything.
