Cam Sensor
Old Apr 12, 2005 | 07:35 PM
macwalnut's Avatar
macwalnut
Cam Sensor
2000 psd will stall at a dead stop and sometime just going down the road, the dealer agrees that it probably is the cam sensor but it will not leave a hard fault that the cpu can record. Will a bad sensor also make it run rough and reduce fuel economy. They will replace it under my warranty, I have 80000 miles but I Only have a month left on years.
Old Apr 12, 2005 | 08:00 PM
touchofgrey's Avatar
touchofgrey
I'd go ahead and get it replaced. But if you've got a $50 deductable......You might want to just buy it, and replace it yourself. The sensor is about $40.00 or less....depending where you get it from. Unless of course.....you don't want to mess with it....then just let them do it.
Old Apr 12, 2005 | 08:01 PM
Robbgt's Avatar
Robbgt
Yea a bad CPS will affect how it runs, and possibly a decline in fuel milage... If there going to do it under warrenty... then have them do it...
-Robb
Old Apr 12, 2005 | 08:47 PM
Phydeaux88's Avatar
Phydeaux88
Where can you buy a CPS for $40.
Ford gets almost $200 for them and International is close to $100.
Old Apr 12, 2005 | 10:04 PM
touchofgrey
The international market place.....Ebay. For those who are interested......check out item #7968091307. New CPS....$40.......21 hours left.......no bids.
Old Apr 13, 2005 | 08:29 AM
macwalnut's Avatar
macwalnut
My deductibile is $100 and they told me the part was over $200 so I thought I should probably let them do it.
Old Apr 13, 2005 | 07:45 PM
Phydeaux88's Avatar
Phydeaux88
Make him give you the old one back and keep it for emergency use. Then learn how to change it, it's not to difficult. That old somewhat defective CPS will be worth its weight in gold if ya get let down out in the stix.
