SCT with EDGE?
Old Apr 12, 2005 | 05:19 PM
flyMike's Avatar
flyMike
SCT with EDGE?
Can you install/run an SCT with a truck that already has the EDGE Power Juice/ATTITUDE kits installed? What's the best overall combination of stuff, for performance as well as truck engine/tranny/etc. safety...at least as safe as can be expected understanding that modifications can be risky. I saw some posts talking about an XCalibrator too. I saw an earlier link to a whole slew (4 things) from SCT, the programmer, a special cable, a chip, etc... The Programmer I was accustomed to only had 3 settings, and you had to reconfigure it with the programmer to change. Where I saw this other post earlier referring to a page that now there is apparently a switch you can install on your dash and switch on the fly...like the EDGE. Then with their chip, you can have them customize the settings to take into account your gear ratio, tire size, etc....and get a new flash if you make changes in the future...even easy to load up by connecting and windows pc to it. I'ld like to make some more mods, but not sure where to start or end up.
Also, I see posts about tranny considerations. What can I do to protect it more? Intercooler? Something else?
I have a 2004 F350 Harley SD, fully loaded, Big cab, long bed. Any suggestions would be greatly appreciated.
Thanks
flyMike
Old Apr 12, 2005 | 10:38 PM
Todder's Avatar
Todder
Do a little search, there is tons of info on this. It will tell ya all you wanna know and then some.
Old Apr 12, 2005 | 11:55 PM
Fastest1's Avatar
Fastest1
The SCT will remedy your tranny issues if you are running the Edge/Attitude combo. You can get just the trans mod and speed limiter removal if that is what you want. call Motorhaven. I think Eric is the programmer.
