Newer model Steering wheel
Old Apr 11, 2005 | 11:54 PM
Broomfieldbum's Avatar
Broomfieldbum
Smile Newer model Steering wheel
Does anyone know if I can put a 60's Steering wheel on my 57 f-100? I just like the design of the wheel better, and I can get one cheap.
Old Apr 12, 2005 | 01:53 PM
GreatNorthWoods's Avatar
GreatNorthWoods
Bum,
I checked into this some time back and if I remember correctly (which is a big "if" these days because my memory isn't what it used to be) the F-series steering wheels will interchange from 40-48, 49-57, 58-60, and 61-64. So my guess is that the newer steering wheel will not work on your older column. It seems to be much easier to go with an aftermarket wheel than trying to retrofit a newer OEM wheel to an older column. If you wanted it really badly you could consider using the later column...
Vern
Old Apr 12, 2005 | 02:06 PM
hiball3985's Avatar
hiball3985
another "IF" I remember, you can use a later wheel but the horn won't work, they changed the design, I've seen 60 type wheels with both designs, do you think if I shoot WD40 in my ear it would loose up the sticky parts of my brain?
Old Apr 12, 2005 | 02:14 PM
GreatNorthWoods
Hiball,
Nope, already tried it and it's a mess to clean out!
Old Apr 12, 2005 | 11:46 PM
51ford fan's Avatar
51ford fan
Originally Posted by GreatNorthWoods
Hiball,
I tried it and the WD-40 just came out the other ear and ran down the wall. LOL
SoCalAngler
May 4, 2020 07:10 PM
MxDad567
Aug 12, 2013 03:18 PM
mwood1973
Feb 15, 2011 06:43 AM
klmracing
Dec 21, 2010 09:38 AM
oldblue31
Mar 21, 2006 12:41 AM
