Sponsored by: Auxito
wheel swap question
Old Apr 11, 2005 | 08:34 PM
68playtruck's Avatar
68playtruck
wheel swap question
I bought a 97 f150 xl with steel wheels that I wanted to replace with alloys. So I found a set on Ebay off a 2002 (same bolt pattern), but the 97 has 12mm studs and the 02 14mm studs and the center caps snap onto the nuts so I need to go to the larger studs. Do alloy wheeled trucks all come with the larger studs, If so would new rotors take care of the front and what will I need for the rear? Thanks.
Old Apr 11, 2005 | 10:16 PM
Smaug's Avatar
Smaug
Ford switched to the 14mm studs in Nov 99. New rotors would take care of the front and the easiest way to go to 14mm on the back would be to swap rear ends. Bonus would be rear discs.
Old Apr 12, 2005 | 11:11 AM
68playtruck
If swapping rear ends is the easiest way what would be the cheepest.
Old Apr 12, 2005 | 11:14 AM
Smaug's Avatar
Smaug
If you can find a rear end in a junk yard, it would probably be the cheapest too.
Old Apr 12, 2005 | 01:08 PM
couleeman's Avatar
couleeman
I would think by the time you bought the other rims and did all the swapping you could buy a nice set of new rim that have the correct size stud holes, ect. Then you don't have all the work involved.
Old Apr 13, 2005 | 07:22 AM
SHUSTANG's Avatar
SHUSTANG
depending on which wheels you have and want to replace, you might be able to jus put your old center caps on the new wheels. there are some that are the same from say 97-03. the stud sizes on the inside are different.
