Engine swap question
Old Apr 11, 2005 | 05:46 PM
Robert R's Avatar
Robert R
Hello i have a 67 F100 i am rebuilding from frame up.
I have a 351w i plan on using in it.
I also have a 72 F250 with a 360.
My question is can i use 360 perches on 351w and install in 67.
The 67 has no engine or perches in it now it originally had a 6 cyl.
Thanks for your help.
Old Apr 11, 2005 | 07:11 PM
Red69's Avatar
Red69
I think the perches are different for the small block and the FE. The FE and I6 may be the same.
Old Apr 11, 2005 | 09:31 PM
Robert R's Avatar
Robert R
Thanks i will find some small block perches
Old Apr 12, 2005 | 02:07 AM
Fomoko1's Avatar
Fomoko1
I always thought the FE and the I6 were the same and the small block (302/351) were different. You should be able to use the small block perches from a 69 up. Theymay also go in a different location from the big block. Best to do a search on this site before you obtain any.
Old Apr 12, 2005 | 07:05 AM
jowilker's Avatar
jowilker
I agree FE & I-6 perches are the same. The 302 used a swept back perch, but think the 302 engine just might fit on the other. I never had two of them open at the same time to compare.
John
Old Apr 12, 2005 | 07:31 AM
4Cammer72's Avatar
4Cammer72
the I6 perches will work if you move them back to the second set of holes in the frame.
Old Apr 12, 2005 | 07:18 PM
Robert R's Avatar
Robert R
Thanks for the info guys.
I dont have the I6 perches but I do have the ones for the 351w in an 82 f150.
The 82 had a i6 originally the 351w is probaly a 70s someone else installed it.
Will the perches from the 82 fit the 67?
Thanks again.
Old Apr 13, 2005 | 05:38 AM
jowilker's Avatar
jowilker
Robert, Ford made changes in the chassis in 80, so check further on you perches before you get in a crunch trying to install them.
65-79 is all bolt up exchange, past that you are on your on.
John
Old Apr 13, 2005 | 04:34 PM
Robert R's Avatar
Robert R
Thanks John i will find some small block perches for 67-79.
There are several salvage yards around here i can check with.
