Distributer
Old Apr 11, 2005 | 12:31 PM
shotgun1987's Avatar
shotgun1987
Question Distributer
I have a 1983 F150 4x4 with a 302 in it. i am putting new head gaskets on it but the distributer will not come out. is there a lock pin or something holding it from coming out or something.
also i was wondering if i sould put new bearings in it sence i ran it with water in the oil , i was going to rebuild the motor but i decided not to put the money into it sence i will be getting rid of it this fall.....
Old Apr 11, 2005 | 06:39 PM
8 Lugs's Avatar
8 Lugs
There is no lock pin holding it in, only the hold down bolt. You need to pry, lift and twist it out and use some WD40.
All of the sixes, 302's and 351's I have pulled out have well worn (bad) rod and main bearings.
I can guarantee yours are borderline (does it knock on a cold start-up)
Do you have low oil press. after slowing from highway speeds to a stop.
Maybe a lower end knock or lifter tick?
No sense replacing the bearings on a old motor that really needs a rebuild!
Steve G.
Old Apr 11, 2005 | 08:13 PM
shotgun1987
Ok thanks for the input the guy that is getting the truck is just going to put a plow on it so it should be a good enought truck for that..........
jkart
Sep 21, 2013 06:55 AM
PSD2005
Feb 23, 2013 06:23 PM
jim1320
Escape & Escape Hybrid
Dec 27, 2009 07:36 PM
herothc2003
Dec 20, 2008 04:03 PM
parks911
New Member Introductions
18
Jul 25, 2005 10:14 PM
