1978 - 1996 Big Bronco
1990 bronco
Old Apr 11, 2005 | 08:24 AM
81bomb's Avatar
81bomb
Thumbs down 1990 bronco
I just got rid of my 81 bronco and i picked up a 90.when i was at the beach the other day i tried to pull a explorer out of the sand but i started to dig myself in alittle so insteasd of 2 trucks getting stuck i decided that i was going to get the rope off.so when i went to back up i could not go anywhere.what could that problem be?it has 33" tires on it.
Old Apr 11, 2005 | 11:45 AM
Kemicalburns's Avatar
Kemicalburns
good be motor out of tune, tranny needing service or rebuilt or gears since you running larger then stock wheels. start with the cheap and easy first. congrats
Old Apr 11, 2005 | 02:34 PM
81bomb's Avatar
81bomb
What brand of plugs and wires should i get?and should i get a distributor and if so what kind?What weight oil and filter should i use?I am new to all of this.
Old Apr 11, 2005 | 02:36 PM
tigerhawk_212's Avatar
tigerhawk_212
do you mean it was spinning tires and you couldn't get out or that the whole truck actually wouldn't do anything at all?
Old Apr 11, 2005 | 02:52 PM
81bomb's Avatar
81bomb
it was not doing anything but reving
Old Apr 11, 2005 | 03:00 PM
3broncocrazy's Avatar
3broncocrazy
I don't think plugs and wires are a concern at this point.
No tire spin at all???
Could be many things - No forward or reverse in any gear and transfer case engaged?
Old Apr 11, 2005 | 03:01 PM
81bomb's Avatar
81bomb
realy, what could it be then and how could i find out?
Old Apr 11, 2005 | 03:07 PM
tigerhawk_212
was it just when you put it in reverse that it wouldn't do anything? what happened when you put it in drive? Did it work after you got unstuck or does the truck still not do anything when you try to drive it? I would like to suggest some parts: Ford Racing 9mm plug wires, autolite standard copper plugs, msd cap + rotor, msd blaster tfi coil, K&N drop in air filter, and a K&N Oil Filter, if your gonna do a tune up at some point.
