Heater Wiring
Old Apr 10, 2005 | 07:23 PM
74fordtruck's Avatar
74fordtruck
Heater Wiring
Alright, just got a 76 f100 on the road. It has factory A/C too. The heater controls (guess the fan really) wont turn on. I didnt see any fuses out either. I'm just wondering if anyone can point me in the right direction in the wires, as to where the heater gets its power, just like a wire I can put the multimeter on or something. THANKS!
Old Apr 10, 2005 | 10:01 PM
74fordtruck
[bump]
Old Apr 10, 2005 | 10:07 PM
Mil1ion's Avatar
Mil1ion
A/C controls are usually vacuum actuated.
You can look under the dash on the heater box for the resistor.
There should be a 30 amp fuse to check.
I'll see if I can find an illustration.
EDIT:
http://www.clubfte.com/users/mil1ion/ACplug.JPG
Old Apr 10, 2005 | 10:29 PM
74fordtruck
Thanks dennis. Thats what I was lookin for. that little guy just plugs into the heater controls, right? There arent by chance color codes for the wires where you found that pic? THANKS!
Old Apr 10, 2005 | 10:50 PM
Mil1ion's Avatar
Mil1ion
The Black w/ yellow stripe should be the wire that goes directly to the fan motor.
It is a very complicated circuit with all sorts of things in it.
Old Apr 10, 2005 | 10:56 PM
74fordtruck
Is there a page by chance that lists the codes? I think I need the wire running to the fan switch too, and if there's another separate ground wire for it. Thanks
