Power window motor stuck
Old Apr 10, 2005 | 06:45 PM
1993F150302's Avatar
1993F150302
Guys,
My passenger window got stuck this weekend in the up position. I don't use that window much at all, so I would assume it's just caught. I can't hear the motor moving either. I took the door panel off, the plastic off, and tried to move the big horizontal arm that moves the window up and down. Nothing.
I can't even tell how the motor/gear box comes out! It looks like it has a few rivets, but I can only find one that's mounted to the box, and my Haynes manual is useless.
Any suggestions? The motor has power going to it, but it appears stuck.
Thank You!
Old Apr 10, 2005 | 08:53 PM
MemOrex's Avatar
MemOrex
I think there are 2 or 3 Bolts holding the motor in. To get one bolt you have to drill a hole in the door. There is a small "dimple" arund the motor area, that's where you drill. The other bolt(s) are easy to get to, you can see them.
Old Apr 10, 2005 | 10:14 PM
1993F150302
There was infact 4 rivets, and I did remove them, and I guess you have to remove the motor before you take the arm out of the door? Once I removed it and re-greased the entire setup and track. It works fine now.
BTW, I messed up that plastic guard pretty well, can I order a new one from Ford?
