A few things
'91 2.3L 4x4 5spd
So I fixed the head gasket (it only took me two months) and all was good...but now...
1. When I come to a stop the truck idles around 1000 RPM, a quick tap to the throttle and it drops. Any ideas?
2. Squeak from the left front wheel, get louder the faster I go. Goes away with slight brake application. Pulled the wheel and the pads are still good. Truck pulls to the right under hard braking. Any other ideas?
3. Any tricks to getting the pins outta the calipers? Is there any aftermarket bolt type set up?
4. When I fill up with gas I end up with a puddle under the tank, like there is a leak in the fill pipe, anyone ever experience this?
Thanks
