Help!!! I Need Towing Mirrors For 99 Expy
I tow a 30' TT with my 01' EB and use the **** #11601. These units slide over, but give you plenty of vision. Got the set from camping world for $42.00. They are molded to fit the Expy mirrors and don't block the stock mirrors. Go on and off in about 60 seconds. I just could not see clamping a full size mirror onto the door frame when this would suffice...
Do you have heated mirrors?
Dawn, If you have the heated mirrors, the slide-on will not work because the mirror housing is larger than with standard mirrors. The **** Universal Tow Mirror works great for us (00 Expy EB), but you have to contact the manufacturer for special clips to better fit the EB's heated electric mirrors.
http://www.campingworld.com/browse/s...21154&src=SRQB
One hint: thoroughly wet the nylon strap before putting it on the truck, it will shrink a little when drying which will take up the inital slack from vibration.
Blaine
Blaine
