whats the best gears to use
not sure how to calculate rolling diameter from the old description ( is the 7.50 the width or the section height ? ) but if that tire is the same height as a 235-75-15 then your revs work out to 3589 rpm. Of course a tire taller than the 235-75-15 would reduce the revs by the ratio of the tire heights and vice versa for a shorter tire.
Regards, john
Regards, john
http://www.pontiacracing.net/js_tire.htm try this site they have a good caculation program. i also have a hand held calculation wheel that i use for drag racing.
to answer your question a 32" Tire, 5.14 gears at 60 mph will turn about 3300 rpm
Originally Posted by TheMadFabber
You doneeed no higher geerz esse... you need a bigger motor!
Pinche cabrone...
Taco power loco,
The Mad Fabber.
Pinche cabrone...
Taco power loco,
The Mad Fabber.
i have a 460/C6 that i want to put in it. with the way gas prices are now. i could never afford to drive it.
Hey PUTO do i know you? por queue to eres un PENDEJO....LOL
on
With a 460/C6 you will want something around 2.80. Ive done a few of those swaps and the first time I started with a 3.50 and kept going taller until I got traction! That 460 puts out some serious torque.
One customer put on an Edelbrock intake/carb and a Jacobs ignition. Claims a steady 16-17 mpg towing a small boat with a 56 F100.
I cant do that good with a 292 Y block.
Originally Posted by low springs
Well, ESSE.
I hang out with you for an afternoon and you forget about me!
Must be all that smoke you were breathing riding with Mike...
TheMadFabber.
#29
#30
on
286merc, did that customer have 2:80 gears?
Yes he does, I found them in a 73 LTD with a 460. Should be the same in big Mercs, Birds and Lincolns as the 2.80 was very common in them. However watch out for some 70's Lincolns and Birds as they use the 9 3/8 rear and they wont work in a 9" housing.
