ATTN BABIN. RE: Your van
Old Apr 8, 2005 | 10:44 PM
pfogle's Avatar
pfogle
Hey, we went through the same thing with our '88. Make sure the grounds are all good. Have you replaced the fuel filter? It sounds like it's getting pressure but if it's less than ~30psi it won't run. THe in tank pumps are only pushing about 7psi, they push it to the pump on the rail, which then steps it up to 30+psi. With KOEO the pressure at the rail should be ~40psi (assuming a V8 model). Auto Zone will rent you a fuel pressure gauge.
