Does anyone know what size generator is necessary to plug into my block heater for my f-800?I need it to run all night.
I think a diesel generator,as opposed to a gas generator would be better.
>How much current does the block
>heater draw? Most generators are
>rated in watts. Amps x
>volts = watts. Example; 10
>amp draw x 110volt =1100
>watts.
I believe it is a 600 watt block heater,it also says 120volt.
