brakes
Old Apr 8, 2005 | 04:51 PM
jeffc1969's Avatar
jeffc1969
Question brakes
can sum1 tell me step by step how 2 bleed brakes on a 93 ranger 4 cyldr 2wd
thanx
Old Apr 8, 2005 | 10:49 PM
ranger_xlt39's Avatar
ranger_xlt39
go to www.autozone.com they have a free online manual for this kind of thing for several vehicles including yours hope this helps
Old Apr 9, 2005 | 06:23 PM
Ken00's Avatar
Ken00
Manual Bleeding
CAUTION: DO NOT allow the brake master cylinder reservoir to run dry during the bleeding operation. Keep the master cylinder reservoirs filled with the specified brake fluid. Never reuse the fluid that has been drained from the hydraulic system.
WARNING: BRAKE FLUID CONTAINS POLYGLYCOL ETHERS AND POLYGLYCOLS. AVOID CONTACT WITH EYES. WASH HANDS THOROUGHLY AFTER HANDLING. IF BRAKE FLUID CONTACTS EYES, FLUSH WITH RUNNING WATER FOR 15 MINUTES. GET MEDICAL ATTENTION IF IRRITATION PERSISTS. IF TAKEN INTERNALLY, DRINK WATER AND INDUCE VOMITING. GET MEDICAL ATTENTION IMMEDIATELY.
NOTE: Bleed the primary and secondary hydraulic brake systems separately.
On the brake master cylinder reservoir , loosen the master cylinder-to-hydraulic line fittings.
Wrap a shop cloth around the tubing below the fitting to absorb escaping brake fluid.
Push the brake pedal down slowly to the floor of the cab. This will force air trapped in the brake master cylinder to escape at the fitting.
Hold the brake pedal down and tighten the fitting. Release the brake pedal . Do not release the brake pedal until the fitting is tightened or air will re-enter the brake master cylinder reservoir .
Repeat this procedure until air ceases to escape at the fitting.
Place a box wrench on the bleeder screw on the rear anti-lock brake (RABS) system valve (if equipped). Attach a rubber drain tube to the bleeder fitting making sure the end of the tube fits snugly around the bleeder screw.
Submerge the free end of the tube in a container partially filled with clean brake fluid. Loosen the bleeder screw approximately three-quarters of a turn.
Slowly press the brake pedal all the way down. Close the bleeder screw, and return the brake pedal to the fully-released position. Repeat this operation until air bubbles no longer appear at the submerged end of the bleeder tube.
When the fluid being expelled is completely free of air bubbles, close the bleeder screw and remove the bleeder tube.
Place a box wrench on the RH rear bleeder screw. Attach a rubber drain tube to the bleeder screw making sure the end of the tube fits snugly around the bleeder screw.
Slowly push the brake pedal all the way down. Close the bleeder screw, and return the brake pedal to the fully released position. Repeat this operation until air bubbles no longer appear at the submerged end of the bleeder tube.
Repeat this procedure at the LH rear bleeder screw. Refill the brake master cylinder reservoir after each wheel location is bled.
Bleed the front brakes starting with the right front brake and then the left front brake as described in Steps 7-11 of this procedure.
When the bleeding operation is complete, fill the brake master cylinder reservoir to the maximum level line.
*2fords*
Jul 11, 2014 07:59 PM
Headviking
Apr 3, 2013 09:11 PM
The Carpathia
All Things Towing
Apr 26, 2011 06:25 PM
Whitey Ford
Mar 19, 2010 01:28 PM
Brock_Samson
Oct 13, 2009 02:24 AM
